Will a GMS .61 Carb Work on Another Engine if ?
Postby Krazy Mike » Sun Feb 28, 2010 7:03 am
The diameter of the base is exactly the same size as in my brand new .65 Magnum GP SE engine ? The problem is this engine doesn't have its carb when it was bought. Any information would be appreciated ? It fits perfectly along with the hold down bolt and nut. Exact fit.
Thank's Guy's,
Krazy Mike... :)
Krazy Mike
Postby SteveM » Sun Feb 28, 2010 8:41 am
If the carb fits with no air leaks then you should be fine.
GMS .61 Carb Fitting on another Engine ???
Postby Krazy Mike » Sun Feb 28, 2010 12:49 pm
Thank's SteveM, much appreciated.
KM... :)
Krazy Mike
Users browsing this forum: No registered users and 137 guests
