K&B 40 Model 8011
K&B 40 Model 8011
Postby Chucky » Sun Jan 24, 2010 9:10 pm
Was given this motor by a friend and am unfamiliar with it. It's the old 8011 with the small front bearing. What would this motor be best suited for in control line flying? Is a venturi and NVA available for it? The one I have has the Perry carb on it.
Chucky
Postby Jim Thomerson » Fri Feb 26, 2010 12:05 pm
The K&B 8011 is fine for CL flying. You can get a venturi from Stuka Stunt, or Lee's Machine Shop. Super Tigre NVA will work fine, but you need the right one. Ask the venturi supplier.
Users browsing this forum: MSN [Bot] and 1 guest
