Hello,
I just bought the GMS 120 for you with the Kavan carb on it? I do not understand the instuctions about the carb setup? This Kavan carb has 2 inlets. One is the high end and the other is I guess for low end? I have never seen a carb with this design. Please explain simple terms on what tubes are connected ect. I tried to run the motor but it wont go past an idel.
The low end idel air mixtute should be set to what bacis setting to start with?? The other inlet on the carb goes to what?? I dont know. Please advise,
Thanks. Roy
