assembly kb 61
assembly kb 61
Postby bliskin » Tue Dec 09, 2008 7:29 am
I bet u guys have answerd this one trillion times. How do you get the pushrod back on the crank after changing the ring????? :oops:
bliskin
Postby chiefss » Mon Mar 23, 2009 1:29 pm
You put the rod on the crank first. Then put the piston in and put the wrist pin in the piston and through the rod. You do this through the hole in the back of the crankcase. last, you put the liner back in.
Users browsing this forum: No registered users and 55 guests
