Purple Carb on 7.5cc In Board early 9181 model
Postby Dan S » Mon Aug 13, 2007 9:51 pm
I can't find anything on that purple carb, it is however identical to the black, red and gold carb early model with the barrel stop screw.
it has a a main needle but no LSN or idle set screw, am I missing something or the idle set screw is not required.
Also when I close the barrel the engine doesn't turn off, I have to cover the carb with my finger to shut it down.
thanks,
Dan.
Dan S
Postby SteveM » Tue Aug 14, 2007 6:55 am
The purple carb has a different bore than the black, red or gold carbs but is otherwise identical. These carbs don't have a LSN and are simple air bleed types. The finger over the carb routine to kill the motor is pretty standard as the carbs aren't well sealed.
Postby Dan S » Tue Aug 14, 2007 8:21 am
Thanks Steve,
now, how do I stop the boat before I it the shore?
maybe I be better off replacing it with a red or gold carb.
Dan.
Dan S
Re: Purple Carb on 7.5cc In Board early 9181 model
Postby SteveM » Tue Aug 14, 2007 9:46 am
Dan S wrote:Thanks Steve,
Dan.
There is a bit of slop on those old style air bleed carbs plus the K&B castings were not always clean and crisp. You might try high temp red silicone sealer on the carb neck that slides into the motor nose piece as a start and see if that helps.
Users browsing this forum: No registered users and 143 guests
