Mccoy 19 Ignition
Mccoy 19 Ignition
Postby Martin Trier » Fri Mar 30, 2007 1:10 pm
Who can help with my Mccoy 19 RR Ignition.
I have install a new Piston liner and new Piston with rings. But the engine hs only little Compression and will not run.
Can I use a liner from another Mccoy 19 with lapped piston.
Or every body know this trouble and can help me.
Sincerely and many greetings from Germany
Martin Trier
Email. matri-rockenthin@t-online.de
Martin Trier
McCoy 19
Postby Matt » Fri Mar 30, 2007 5:26 pm
Hi,
Assuming you used the correct parts, and they were indeed new, you are losing compression someplace else. Check head and gasket, also the front cover, maybe even your plug.
A cylinder liner from a lapped piston model will NOT work in the RR version, entirely different.
Matt
Matt
Users browsing this forum: Google [Bot] and 90 guests
