starting a k&b inboard
Re: starting a k&b inboard
Postby SteveM » Fri Jan 05, 2007 9:42 am
You need to spin the outboard starter cone in a clockwise direction which is the opposite of how you'd start an airplane motor. Just reverse the leads on your starter.
jtpump wrote:i am having trouble starting a 82 k&b inboard looking at it from the flywheel side
which way does it turn clock wise or ccw
82 inboard
Postby jtpump » Fri Jan 05, 2007 9:52 am
thanks i thought it was starting backwards because as soon as it started and i gave it throttle it would die thanks again,
jtpump
Postby lh7018 » Fri Jan 05, 2007 10:49 am
Inboards, looking at the flywheel end, spin ccw. Outboards spin the opposite.
lh7018
Users browsing this forum: No registered users and 85 guests
