safe rpm limits for Cox gray props
Postby diesel_don » Thu Mar 09, 2006 8:59 am
Anyone know where such data is published? Particularly for from smallest diam up to say 8X4-,9X4. TIA,Cheers; diesel don
diesel_don
Postby Jim Thomerson » Thu Mar 09, 2006 3:45 pm
I've blown blades off two Cox grey 8 x 4's at around 14,000 on an ST G20-15 diesel. On the other hand I've run them up to 17,000 with no problem on a Cox 15 special. The 7 x 3.5 is fine at 15,000 on a TD 09 and I've run them at 17,000 for short periods without failure. I think diesels and glow engines put different stresses on props, but that's opinion rather than fact. I don't know if there is published limit data.
Postby ffkiwi » Thu Mar 09, 2006 9:33 pm
The 7x3.5 Cox grey used to have an rpm limit of 19,000 embossed on the blade-but I don't recall whether this was the case for the others. Hobby Lobby, who stock Graupner props, used to have something in their (IC)prop section which was a formula for calculating the rpm limit for each size of Graupner prop (the grey ones)-I suspect that somewhere on the APC prop site there will also be something on prop rpm limits-alternatively you could ask them thru the 'query' function on the website
'ffkiwi'
ffkiwi
