shouid it run out side of water
Postby nitrorc5 » Wed Jun 08, 2005 10:50 am
i have a k&b 35 engine (is very old)
it only runs for some seconds out side of water so i dont get a chance to put it in water
it revs high and then shuts off
the lines are new and the tank shows no signs off holes
i think its just the nippel on the engin thats filled with oil and does not comprees the tank(it starts but than is starved of fuel)
but im new to nitro boats so i dont know if the engin is suposed to rev high out side off water(when it stops runing iratic)
on my .18 os engines that are on my cars and trucks when this happens its becuse the low speed nedal is to lean but on my engine it has nothing on the carb to ajust the air mixture what carb do i have and whats the model # to get a new one
also the engin is not to lean at all its very rich and i play arond with the high speed seting but i get the same thing revs than stops how do i ajust the air mix
and is their another carb that can be tuned essyer whats the model #
thank you for any help
nitrorc5
Postby nitrorc5 » Wed Jun 08, 2005 6:18 pm
and also i forgot to ask
the person that had the boat with the engine before me siad that when it started to run normaly that i should accelerate like half throtal and throw the boat into the water so that it does not stop when it is placed in the water im used to letting my r/c car engines warm up in idal befor i start to engage the cluth to move the car so that the sleve has time to expand
will eccelerating so fast after the boat engine start ruin my engine? or are theas engins stronger than my o.s .18
should i let the boat engine idel before i accelerat or just let it rip right :shock: after it starts?
nitrorc5
Postby hiperflyte » Sun Jun 19, 2005 10:23 pm
sounds like its going lean , may be some crap stuck in the spraybar....but then again it could be a jillion things, outboards are real finicky and dont like to idle , itll heat up then seiz up cause their water cooled. infact I broke a rod last yr cause I didnt get it in the water in time, if your sure everythings dailed in just fire it up and throw it in.............o
hiperflyte
Users browsing this forum: No registered users and 15 guests
