Clockwise Rotation
Clockwise Rotation
Postby Dago » Wed Dec 22, 2004 8:48 am
What is the proceedure to have a 7.5 engine run reliably backwards for twin inboad installations?
Dago
Postby tperry2054 » Thu Dec 23, 2004 7:23 am
If it is a front rotor, you will need a new crankshaft with the intake cut for the correct timing. If rear rotor, you need a rotor timed for clockwise running. You might consider offsetting one engine and use a 1:1 gear for shaft reversal.
tperry2054
Reverse
Postby max hansen » Thu Dec 23, 2004 9:13 am
If it is a older engine with a bolt on front end you can take the bolts out & turn the front end 90 degrees to the left & it will run backwards . If I remember right ? Good luck , MAX H. :lol:
Users browsing this forum: No registered users and 15 guests
