by JOHN G » Mon Oct 01, 2007 4:29 pm
THANK YOU CHIEFSS:
I GUESS THE BEST THING TO DO WOULD BE TO BUY READY MADE
AND ADD CASTER TO IT I FLY SOME OLD GLO AND IGN WHICH
NEED 25% OIL I ALSO FLY NEWER ENGINES 2000 ETC THAT CAN GET BY WITH THE NEWER FUEL LAST WHAT IS AND WHERE DO YOU GET BAKER'S CASTER AS YOU CAN TELL IVE BEEN OUT OF THE LOOP
FOR SOME TIME
MANY THANKS JOHN G 5344
JOHN G
by robert mathison » Wed Mar 05, 2008 6:09 pm
HI John, some of the control line people in VIRGINIA mix there fuel but most are doing what you said you , just buy some and add caster.
BOB
robert mathison
by JOHN G » Wed Mar 05, 2008 7:02 pm
ROBERT
THANKS
JOHN G
by SnowOwl » Fri May 02, 2008 5:23 am
SnowOwl
by SnowOwl » Fri May 02, 2008 5:28 am
Sorry, the link I included doesn't take you right to the Castor oil.
Go to the link,
click on Field Equipment,
then on Fuel additives,
then on Fuel-Oil
and it opens the page with castor oil and Klotz
SnowOwl
by JOHN G » Sat May 03, 2008 7:03 am
TEST TO SEE IF THIS WORKS---THANK YOU
JOHN G
by pchall » Mon Jun 09, 2008 10:08 am
Fox still sells Missile Mist (24% nitro/17% castor) by the quart and the gallon. Missile Mist ought to make any 1/2A glow run happily.
http://www.foxmanufacturing.com/
pchall
by Garf » Sat May 24, 2014 6:44 pm
Fox has given up making fuel and engines.
Garf
Return to 1/2A and alike
Users browsing this forum: No registered users and 41 guests
