by bogateer » Thu Aug 10, 2006 11:34 am
Any body have an early model..either .049 or .051 Killer Bee they's wish to part with? I'm looking for the circa 1996 or before version that put out real power versus the current crop of renamed Babe Bees.
Rob
bogateer
by jim paton » Mon Aug 21, 2006 8:47 am
Why not go for a TD049. They are still available and they are the most powerful Jim
jim paton
by viking61 » Wed Aug 23, 2006 5:16 am
Another way to put life intp current KB is install Davis diesel crank. Find older true tapered TD piston and liner. Increase intake size, install a teflon reed. This will put you over 20,000 rpm's. 25% nito fuel and add a couple head shims to save plug. Also Nelso head botton and plug. You will have some bucks into engine but a screamer. Or like what was said use a older TD . A taper p/l you can not push piston out through the top.
Dan
viking61
Return to 1/2A and alike
Users browsing this forum: No registered users and 32 guests
