FK-50 Cylinder and Head removal
Q&A on the KAVAN FK-50 twin now owned by MECOA
Postby bdtsr1 » Sun Jan 28, 2007 8:03 pm
Could someone please help me with removing the cylinders and heads? I just bought this FK-50 MKI and it is really gummed up bad. I saw the small set screw but am not sure how the heads come off. I can't get to the last cylinder base nut due to the pushrods being in the way. Any help would be appreciated.
bdtsr1
Postby MECOA » Sun Jan 28, 2007 9:14 pm
The set screw is the early version. The screw pushes against a notch in the threaded protion of the cylinder in the tightening direction.
This was later done away with. I would not remove the cylinders from the heads. You have to use a strap wrench and internal collet to hold it. You will have to replace the head gaskets if you remove the heads.
To remove the nuts you can actually remove the rockers and push rods then the push rod tubes will come off by pushing them in one direction, towards the head I think. I don't have one to look at here, I am at home right now, but I know it will push in one direction or the other and pop out.
Be sure to see the exploded view at
http://www.mecoa.com/kavan/eng_parts.htm
Postby bdtsr1 » Tue Jan 30, 2007 7:22 pm
Thanks for the quick reply! Yes I see how the pushrod tubes would slide to the crankcase for removal. Problem is they are pretty well stuck. Are new pushrod tubes and boot seals available? If so, it may be easier to cut the old ones out and install new ones when putting the engine back together.
bdtsr1
Postby MECOA » Tue Jan 30, 2007 9:13 pm
Right now they are not but we are planning on making them in the next few months
Postby bdtsr1 » Thu Feb 01, 2007 3:06 pm
How about the cam gear? My nylon one has two teeth broken off.
bdtsr1
Postby MECOA » Fri Feb 02, 2007 8:25 pm
Same thing there. I do have the idle gear with the roller bearing.
Postby bdtsr1 » Wed Feb 07, 2007 4:03 pm
The gear I need is the one between the camshaft gear and the crankshaft gear. Is this the one you have?
bdtsr1
Postby bdtsr1 » Wed Feb 07, 2007 9:04 pm
I believe the part# is 250/33. Would I need a new mounting block for the metal gear as well # 250/34?
bdtsr1
Postby MECOA » Sat Feb 10, 2007 9:11 am
Yes we have this one
Return to Kavan FK-50 Engines
Users browsing this forum: No registered users and 23 guests
