Ok, its been a while so can someone remind me.......
Whats the best way to achieve a balance on a prop when balancing? Should material be removed from the heavy side blade? if so how and where? or should something be added to the light side blade? again. how and where?
Bit of a dumb question but I like balanced blades, kinder to the engine and airframe.
I can remember sanding and even cutting the tips on props when I was younger but I'm sure there is a better way! Thanks.
