Fuel delivery
Postby Frank Klenk » Sat Nov 13, 2010 7:16 am
Yes, you can install a simple pin that will only allow the screw to be rotated 1 revolution. Running the engine first will determine where to set the compression and then you can install your pin. Once you run a diesel you'll soon figure out where to set it. Too much compression will result in overheating and sagging rpm, almost like a lean needle and a terrible pinging noise!
Frank
Postby chiefss » Sat Nov 13, 2010 3:24 pm
The engine slows down and starts making a knocking noise.
Previous
Users browsing this forum: No registered users and 22 guests
