Starting and Running the Original Gotham DEEZIL
Would your old Deezil run
yes
1
33%
no
2
67%
Total votes : 3
Postby davideo4301 » Fri Sep 10, 2010 5:07 pm
I finally managed to start one and see it run under it's own power. Those old enough to remember this cranky old beast will be amazed to see how it was done. The rest will wonder what all the fuss is about. The link below describes the steps taken to achieve this astounding success. :wink:
http://antiquemodelenginesrunning.blogs ... eezil.html
davideo4301
Postby Frank Klenk » Sat Oct 23, 2010 2:08 pm
Thank you for sharing that with us. Appreciated!
DEEZIL VID
Postby davideo4301 » Mon Oct 25, 2010 2:45 pm
Frank Klenk wrote:Thank you for sharing that with us. Appreciated!
It's my pleasure! It wouldn't have happened without the help of members of this forum.
davideo4301
Postby Frank Klenk » Fri Nov 12, 2010 5:18 pm
Hi David
I cast my vote with a no. Based on the compression it does not have. You mentioned you used 70 weight oil and this improved compression. I mixed my fuel with castor oil and compression was still lousy. Me thinks it needs some rework?
Frank
Deezil Fuel
Postby davideo4301 » Thu Nov 18, 2010 4:35 pm
Frank Klenk wrote:Hi David
Frank
The makers of the old Deezil never intended it to run on conventional diesel fuel. I had a look at the manufacture's directions and they were specific, recommending a fuel mixture of 70% 70 weight oil and 30 % ether. I couldn't find 70 weight oil so I used summer weight chain bar oil to cause it to fire.
davideo4301
