Need thrust washer Taifun 2.5cc diesel Rasant
Postby viking61 » Sun Aug 19, 2007 4:28 am
Have a engine that has a crack in thrust washer. Engine has very good compression but binds when tighten the prop bue to a crack. Shame as it looks like it would be a nice runner. Also could use a needle vale for same.
Dan
viking61
Postby ffkiwi » Wed Sep 05, 2007 12:56 am
You will cause yourself (and [i][b]others) untold grief and confusion if you do not know the difference between Taipan and Taifun.
TAIPAN is/was an Australian brand of model engine manufactured by Gordon Burford and Co. [Taipan brand glowplugs are props are still being manufactured, but not by the original supplier]
TAIFUN is the name of a range of German made engines dating from the early 50's to the late 60's and manufactured by Hans Hornlein and Co. [He later went on to manufacture the Profi range of R/C engines.]
The Rasant is a plain bearing 2.5cc diesel of TAIFUN manufacture. There is a series 1 and a series 2 which are quite different in appearance. 'Valentine's Diesel shop' on Ebay deals on original and replica Taifun engines and parts. They're about the best bet for parts these days.
'ffkiwi'
ffkiwi
Taifun 2.5cc
Postby viking61 » Sat Sep 08, 2007 7:05 am
FFkiwi is correct, engine was sold as a Taipan but is a Taifun.
Viking61
viking61
Users browsing this forum: Majestic-12 [Bot] and 12 guests
