disassemle a K/B 61
disassemle a K/B 61
Postby jaejon465 » Sun Dec 07, 2008 11:36 am
I need to change bearings on my .61. The piston sleeve is out, the prop shaft is out. The forum tells me to remove crankshaft, I need to heat crankcase and use an arbor press . OK, my need to know is: How do I remove the prop drive, and how do I get the connecting rod off the crankshaft pin? this is engine made between early 80s and 1990 w/ square carb body.
Any and all assistance greatly appreciated.
John
jaejon465
K&B .61
Postby max hansen » Thu Apr 02, 2009 8:54 pm
Did you ever get this apart ? Max H.
Postby jaejon465 » Sat Apr 18, 2009 3:39 pm
Sorry took so long to reply. Yes, got it apart, a friend showed me how.
Thank you,
John
jaejon465
K&B .61
Postby max hansen » Sat Apr 18, 2009 4:30 pm
Good show John , Just hated to see the poor old engine laying there with hammer marks all over it . CYL, MAX H. :)
Users browsing this forum: No registered users and 127 guests
