OS FS-60 prop drive washer removal
Postby jaregalbuto » Thu Nov 16, 2006 11:03 am
How is the prop drive washer attached to the crankshaft of the the open rocker FS-60? Is it a press fit? Threaded? I have tried to press the crankshaft out of the drive washer with no luck. Not enough force available? It is a puzzlement!
John Regalbuto
jaregalbuto
FS-60 Drive washer
Postby max hansen » Fri Nov 17, 2006 9:39 am
The washer on this engine is held to the crankshaft with a tapered sleeve & needs to be pulled from the front . You might get by with a battery post puller but OS makes a special puller that fits most all their engines . Later OS 4-strokes had a small key to hold the washer from rotating & you can ID them by the timing marks on the rim of the washer.
Trying to drive or press yours off just makes it tighter.
Good luck, MAX H. :lol:
Os fs-60
Postby jaregalbuto » Fri Nov 17, 2006 3:13 pm
Max H.
Thanks. After I wised up and looked at the front end closely I realized the truth. A friend supplied a puller and disassambly was easy. Ignorance in action is awsome to behold!
I proved that later in the attempt to remove a flat head screw which retained a bearing to an internal gear in the train to the camshaft.
The screw is left-handed.
The result was inevitable. Broken screw. No idea of where to get a replacement. Any ideas?
Thanks again, Max.
John Regalbuto
jaregalbuto
Screw
Postby max hansen » Fri Nov 17, 2006 9:14 pm
Best I can tell you is to go to the wanted site on here & ask for one , you never know who may have one .
Why are you stripping this engine down so far ? Is it gummed up ? Bearings lumpy? I usually wash them out in straight alcohol from a paint store or maybe a race car shop . I have found that is the only liquid that will disolve old castor oil . Even using glow fuel will help .
I bought a engine like yours awhile back & it was stuck ,heat unstuck it & then washed out with alcohol to free the bearings , a quick run & all is well. Good luck , Max H. :lol:
OS FS-60
Postby jaregalbuto » Sat Nov 18, 2006 6:49 am
All the bearings were rough and noisy.
Thanks for the reply.
jaregalbuto
Postby chiefss » Mon Oct 01, 2007 5:15 pm
Did you find a screw for the cam shft or the shaft?? I have some
Postby chiefss » Sun Nov 16, 2008 9:53 pm
Did you ever find a screw
Postby chiefss » Fri Mar 06, 2009 4:37 pm
Did you ever find the screw?? I have one
Users browsing this forum: Majestic-12 [Bot] and 48 guests
