by Krbtfd » Wed Jul 12, 2006 5:27 am
I have a 28 Sportster and was flying well however recently the engine will start and fly for about 3-5 min. Then it will cut out.
I have changed glow plugs, needle settings and replaced the fuel tank(newlines and tank).
Any suggestions what might be the cause of the problem and how to remedy it.
Thank Kevin In St Thomas
Krbtfd
by max hansen » Wed Jul 12, 2006 5:58 pm
Think I would take the assembly out of the side of the carb & ck for trash in the area between the two "O" rings . A little junk will give problems . Ck head & rear cover bolts . Good luck , MAX H.
Users browsing this forum: No registered users and 65 guests
