low speed on an inverted glow engine
Postby RUDYFKASSEL » Sat Jun 24, 2006 5:17 pm
Does anybody make a glowplug lighter to install in plane for low speed on a inverted engine for two or four cycle
Rudyk
RUDYFKASSEL
Postby Frank Klenk » Sat Jun 24, 2006 6:15 pm
Hi Rudy
From your post I figure you're after an onboard glow system to keep the plug lit at low idle? If so McDaniel r/c, Sonic Tronics makes a good product, check out the link ... http://sonictronics.com/xcart/customer/home.php
Enjoy.
Frank :)
Postby jeffro » Thu Mar 05, 2009 12:43 pm
I read a good thread about this . A northern guy mounted a cheap toggle switch at the carb so when he throttled up it flipped the glow off and on down throttle it flipped it on. had it's own little battery too I think :D
jeffro
Users browsing this forum: No registered users and 57 guests
