older K&B engine
older K&B engine
Postby Crash-N-Swim » Sat Dec 17, 2005 7:07 pm
I have an Older K&B engine 40. I need to replace the bearings in it and have no idea how old it is. How do I know what bearings to replace and which ones to order.
Crash-N-Swim
Postby William Robison » Tue Feb 21, 2006 6:12 pm
Crash:
Two possibilities. If you have the later 40 engine with the prop drive mounted on a centering cone the front bearing is an R6. if instead you have the earlier version with the pro0p rive pressed on the 1/4" nose of the crank shaft the front bearing is an R4. In either case therear bearing is an R8.
Hope this helps.
And sorry it took so long for a reply, I just joined this forum.
Bill.
William Robison
Users browsing this forum: No registered users and 56 guests
