K&B 40 Throttle range
Postby JSRagman » Mon Nov 07, 2005 2:09 pm
I have an older K&B 40 with the large square carb. My engine seem to peek out at half throttle on the carb. I have very little speed range with this engine ilde and full powe very little happens between half and full throttle. I have put more than a gallon of fuel through the engine between break in and flight time. Any help would be great.
JSRagman
oh, eh
Postby Victoria62589 » Wed Dec 28, 2005 11:50 am
JSRagman wrote: I have put more than a gallon of fuel through the engine between break in and flight time.
What exactly do you mean when you say "time."?
Victoria62589
K&B 40
Postby JSRagman » Thu Dec 29, 2005 4:33 pm
Flight "time" time in the act of flight.....
JSRagman
Postby loucrane » Sun Jan 01, 2006 1:21 pm
JSR,
Do you have the instructions for your engine? There should be some set-up guidance in those. If not, possibly the host here could help, or take a look at the engine salesroom in here to see if your engine is still available. Most have on-line instruction books avaiable.
Other things that could affect your problem: prop, fuel, glow plug, carb set-up, even outside things like air leaks in the tank, the fuel line, or around the carb base.
If it is basically the classic 4011, it should be a solid dependable and powerful horse for you.
Next!
Users browsing this forum: Majestic-12 [Bot] and 46 guests
