Fox 15
Fox 15
Postby Bob Mears » Thu Jan 06, 2011 6:04 pm
I've recently acquired my fathers old engine collection. In it is a Fox 15, with the case split vertically. It has bolts running through the mounting lugs holding the front and back together, along with a couple more bolts about half way up. I've never seen such an engine. Does anyone know when it was built, and how rare it may be?
Bob Mears
Postby chiefss » Thu Jan 06, 2011 9:22 pm
Check again. The only Fox with a split case in that size range was a 19. It came a as a single needle or a two speed. Made in 1953. As far as rare, I don't know. I've never seen one.
Sells for $125 to $150 at MECA, Poor design and couldn't keep gaskets between the halves. For a buck you could send it back and get a one piece case engine. Many were returned so there probably aren't many around these days. Want to sell it?
Fox 15
Postby Bob Mears » Fri Jan 07, 2011 7:36 am
I'll look again tonight and make sure if said 15 or 19.
I'm thinking about listing it on ebay.
Bob Mears
Postby Bob Mears » Sat Jan 08, 2011 6:28 pm
chiefss wrote:Check again. The only Fox with a split case in that size range was a 19. It came a as a single needle or a two speed. Made in 1953. As far as rare, I don't know. I've never seen one.
Well, I looked and there's no markings on it saying what size it is. But it must be around the 15 to 19 just by looking. I'm sure its a 19 since you already know more about it than I do. It seems to be in good shape. great compression. I'm sure its like new since its obvious this poor design probably wouldnt run long enough to wear out.
Bob Mears
Fox.19
Postby max hansen » Sun Jan 09, 2011 5:26 am
Bob, I have one like yours listed on ebay now . You can look at mine & match it to yours & also see what it will bring . Good luck to both of us,Max H. :)
Postby chiefss » Sun Jan 09, 2011 4:41 pm
Info on it is in Anderson's Blue book and The Encyclopedia of American Model Engines.
Re: Fox.19
Postby Bob Mears » Sun Jan 09, 2011 5:00 pm
max hansen wrote:Bob, I have one like yours listed on ebay now . You can look at mine & match it to yours & also see what it will bring . Good luck to both of us,Max H. :)
Yep, thats the one. I'll watch and see what it brings. What are you expecting it to do? Ebay is so strange. I sold a cyclon pc4 for 180.00. so I put another one one there...brought 80 bucks. I just sold a cyclon fortune 15 for 150.00. put another one on and it looks like its only gonna bring 100.00. Same motors in excellent shape. Ya just never know.
Bob Mears
Fox "Splitcase"
Postby max hansen » Sun Jan 09, 2011 5:37 pm
Bob, I don't really know just what it will bring. The Anderson Blue Book shows from a $100.00 to $360.00. I have a reserve on mine so it won't go real cheap. You got one & I got one ,wonder where the other 48 or so are at ?
I doubt if anyone can figure out what or why things sell like they do on eBay or other places.
I would like to find a item new in the box ,has a Ford emblem on it & is held on with one screw. Ebayers would go nuts!
Hang in there . Max H. :roll:
Postby Frank Klenk » Sun Jan 09, 2011 7:09 pm
Hi Bob
I like to follow your ebay sales. What's your handle?
Max, I have yours and you sell some pretty cool stuff!
Frank 8)
Postby chiefss » Sun Jan 09, 2011 7:13 pm
You should see what Cox Babe Bee 049's have sold for on ebay. And Cox only made 25 million of them. I saw one go for 75 bucks.
Postby Bob Mears » Sun Jan 09, 2011 7:29 pm
Frank Klenk wrote:Hi Bob
Frank 8)
RX8Guy. I havent had a store long. Just decided I had way too much stuff that needed to go. I have a buch of 1/2A combat motors that I've sold and still plenty to sell. And a lot of Fast Combat motors too. Fox 36's mostly. So far I'm not willing to part with my Nelsons or my Wiley's.
Bob Mears
Postby Bob Mears » Sun Jan 09, 2011 7:35 pm
And my Cyclon brought $150.00. Good buy for somebody. And out of my engine drawer
Bob Mears
Postby Frank Klenk » Sun Jan 09, 2011 7:47 pm
How much were they brand new Bob? Must of been over $300?
Postby Bob Mears » Mon Jan 10, 2011 9:38 am
They were $250.00 And I understand now that Alexander Komokav (spelling?) is not going to produce any more engines. I've still got a couple of pc5's that I will sell, 10 pc7 and 7m's that I just cant let go of, 3 Zalp's, 10 AKM's, 6 Foras. Got motors everywhere. All I need is 6 top notch motors to compete. I prefer the PC7's but he quit building those about 5 years ago. Guess I'm going to switch to the Fora's
Bob Mears
Postby chiefss » Mon Jan 10, 2011 8:20 pm
[quote="Bob Mears"][quote="Frank Klenk"]Hi Bob
Frank 8)[/quote]
RX8Guy. I havent had a store long. Just decided I had way too much stuff that needed to go. I have a buch of 1/2A combat motors that I've sold and still plenty to sell. And a lot of Fast Combat motors too. Fox 36's mostly. So far I'm not willing to part with my Nelsons or my Wiley's.[/quote]
Got any Johnson's
Postby Bob Mears » Tue Jan 11, 2011 7:37 am
Several. Most of them mounted on nostalgia combat planes. along with green head torp, red head fox, black head fox, super tigre, willey, nelson, veco, topr stallion, red head mcoy...
Bob Mears
Postby chiefss » Tue Jan 11, 2011 2:54 pm
Looking for JBB, JCS and 29R.
Fox
Postby viking61 » Tue Jan 11, 2011 7:43 pm
Old combat ships WOW !! I have one Sport special I worked on and got it running pretty good. Foue C/S's in good shape, and one maybe unrun.
Last is a RC with bearings. Sorta like a JBB with a carb. I saved the carb and have parts to another, The engine looks just like C./S but compression was not as hi. It will hold a seal for very long time so P/L are good. One of the C./s put some airtime in a Ringmaster.
Dan
viking61
Postby chiefss » Thu Jan 13, 2011 1:46 pm
The JRC is a JBB with a carb.
Re: Fox "Splitcase"
Postby Bob Mears » Fri Jan 14, 2011 4:59 pm
max hansen wrote:Bob, I don't really know just what it will bring. The Anderson Blue Book shows from a $100.00 to $360.00. I have a reserve on mine so it won't go real cheap. You got one & I got one ,wonder where the other 48 or so are at ?
I'm surprised its as low as it is. I think they're worth more than that to just look at what a piss poor of an idea it was!
Bob Mears
fox 19
Postby max hansen » Fri Jan 14, 2011 7:37 pm
Bob, I guess that there must be only 48 Fox collectors & they all have one . You & I have the other two. Guess I will keep mine . I do think selling with no reserve brings more bidding & higher prices. Sometimes you win & some you lose. Like I said ,it needs a FORD emblem on it . CYL, Max H. :(
Postby chiefss » Fri Jan 14, 2011 7:54 pm
If you read what it says in the blue book you would see that Fox would give you a new engine if you sent the old one back. Being that it was a poor design, I would bet that many of them were sent back to get one that would work. That means there aren't 48 others out there. Probably very few.
Postby dedaddy007 » Fri Jan 14, 2011 9:20 pm
The bottom is dropping out of the collectable engine market, just like baseball cards a few years back. There are a lot of old collectors passing away and their collections are being liquidated. I know of one collection that was appraised at $99,000 three years ago is only going to bring about $40,000. Now all the old guys are panicing and dumping their stuff. I was at the MECA national meeting in October. One of the stunning statistics was the membership averages 72 years of age and is shrinking at about 10-15% per year. No new members are coming in. Nobody wants to collect newer (50's and 60's) engines because there are so many of them, they are cheap and most are looking for something that will appreciate. In this economy they won't. If you look at it as a hobby, it can be fun, but if you want to make money, it is a drag.
A Fox split case .19 ended bidding on eBay at $27 with two bids and the reserve was not met. I think this is a sign those old price books are way too optimistic. Engines are only worth what you can get for them, not what you pay for them.
dedaddy007
fox & cox
Postby max hansen » Fri Jan 14, 2011 9:53 pm
Well troops the two Foxes were a no sale. Both are very nice old chugs even if they came with problems from the factory. The Cox MKII did good at 246.00 so maybe I should put Cox stickers on the Foxes ? Guess I will relist again later. Been on this old earth long enough to know you can't win them all. CYL, Max H. :?
Postby chiefss » Sat Jan 15, 2011 1:15 pm
I haven't seen any evidence of the "bottom falling out of the model engine market".
$246 for a Cox MkII is a good example of the bottom staying right where it belongs.
Have you seen what M&M's are gong for?
Postby fersanda4 » Sun Apr 17, 2011 9:31 am
interesting information!!!
fersanda4
combat engines
Postby Fermin » Tue Apr 19, 2011 11:56 am
Bob Mears wrote:They were $250.00 And I understand now that Alexander Komokav (spelling?) is not going to produce any more engines. I've still got a couple of pc5's that I will sell, 10 pc7 and 7m's that I just cant let go of, 3 Zalp's, 10 AKM's, 6 Foras. Got motors everywhere. All I need is 6 top notch motors to compete. I prefer the PC7's but he quit building those about 5 years ago. Guess I'm going to switch to the Fora's
Dear Friend;
Ian interested in a couple of CYKLON PC-5,1 AKM; Will also buy discontinued combat 2.5cc in running condition.
Fermin
Fermin
