by frankjames883 » Sat Feb 20, 2010 3:22 pm
Getting back into planes after thirty year lay off.Bought a Mc coy #5 .049 the guy said it might be a .051 1960 era I think.What type of fuel should I run .Any outher help or info will be greatly apprieciated.
frankjames883
by chiefss » Sun Feb 21, 2010 12:39 pm
McCoy never made an 051. You want to use high notro in small engines. At least 25% and use castor oil.
I wouldn't run it as it uses a special plug and they haven't been made in years. You blow it and that's that.
There are many better engines available that that have a better parts availability. Cox is one of the best. Mecoa is making plugs for Cox engines again.
by frankjames883 » Mon Feb 22, 2010 8:46 pm
Thanks for the heads up , guess I'll put it up till I find a couple of glow plugs.Yea I found out about the fuel,sig 25.Any way I appreciate the info.
frankjames883
Users browsing this forum: No registered users and 49 guests
