Cox Medallion .15
Cox Medallion .15
Postby walt » Wed Jul 30, 2008 11:08 am
Did the Medallion .15 come with a ball and socket piston or did it have a piston pin as with the Cox Special .15 MK II?
walt
Postby Jim Thomerson » Wed Jul 30, 2008 3:22 pm
Yes. The two Medallion 15's I have had both had piston pins. I have seen a NIP Medallion 15 cylinder and piston which had a ball joint in the piston. You pays your money and you takes your chances!
Postby walt » Wed Jul 30, 2008 6:05 pm
Thanks, Jim. I have one used one that has a piston pin. Not sure what my new ones have.
walt
Re: Cox Medallion .15
Postby ffkiwi » Thu Jul 31, 2008 10:07 pm
walt wrote:Did the Medallion .15 come with a ball and socket piston or did it have a piston pin as with the Cox Special .15 MK II?
My experience with them is that the std one (single bypass, twin exhaust ports) came with a ball and socket joint little end, whereas the R/C version-the type with the ground cylinder OD and a rotating exhaust restrictor throttle-has twin tranfers, twin exhausts and a conventional gudgeon pin a la Cox Spl 15 Mk2.
So both types were made.
'ffkiwi'
ffkiwi
Postby walt » Fri Aug 01, 2008 5:00 pm
Hmmmm, also good information, and interesting. I'll have to take this one apart and look closely to see how it compares with your description.
Thanx.
walt
Users browsing this forum: No registered users and 50 guests
