Brown model "H"?
Brown model "H"?
Postby spacebug.049 » Mon Jul 27, 2009 7:59 pm
I have what I believe is a Brown Junior. However, there is no serial number on the case and instead, "H11". I checked Anderson's Blue Book and there was no H11. Does anyone have any idea what engine it is?
Thanks, Hunter
GO COX!
spacebug.049
Postby chiefss » Tue Jul 28, 2009 2:25 pm
A picture would help
Postby spacebug.049 » Tue Jul 28, 2009 5:02 pm
I'll get a picture as soon as i can.
GO COX!
spacebug.049
H11
Postby herbata » Wed Jul 29, 2009 9:47 am
Suggest you look carefully at the bypass on the front of the cylinder to see if there is any writing on it. Your engine may also have a flared end to the intake tube? Is the crankcase sandcast? You may like to have a look at the 1st model Hurleman Aristocrat in the Anderson book. If it is one & it's 100% right then you have yourself a very desireable motor in your hands. A photo would confirm.
herbata
Postby spacebug.049 » Wed Jul 29, 2009 7:49 pm
spacebug.049
Postby spacebug.049 » Wed Jul 29, 2009 7:50 pm
spacebug.049
Postby spacebug.049 » Wed Jul 29, 2009 7:52 pm
spacebug.049
Postby spacebug.049 » Wed Jul 29, 2009 7:56 pm
spacebug.049
Postby chiefss » Wed Jul 29, 2009 9:26 pm
Looks like a Hurleman Aristocrat but the tank is wrong.
H11
Postby herbata » Thu Jul 30, 2009 12:37 am
Yep, very nice & rare Hurleman Aristocrat from 1933. Sadly someone has shortened the intake tube but this could be relatively easily replaced. There's an extra hole in the mounting lug and some other minor "seen use" details. Over all a very disirable collectors engine.
herbata
Postby spacebug.049 » Thu Jul 30, 2009 8:22 am
The timer really looks like a Brown timer and so does the cylinder. Was it maybe switched? How much are the Aristocrats worth?
GO COX!
spacebug.049
Postby chiefss » Thu Jul 30, 2009 9:33 am
It's definitely not a brown. There were several different versions of the aristocrat in different sizes. They have differnt values. Yours has been hevilay modified which brings the value down substantially. The first came out in '34.
Postby spacebug.049 » Thu Jul 30, 2009 1:19 pm
I know very little about this engine. What parts have been modified?
spacebug.049
H11
Postby herbata » Fri Jul 31, 2009 11:56 am
Walter Hurleman designed the timer assy - it's the same as those fitted to the Brown Jr. As to the cylinder - does the top fin have 2 holes in it or none? Is there any writing on the bypass? If not then the cyliner is probably a Brown. However do look carefully in proper daylight as it was etched on and could be quite hard to see - the most obvious mark will be a capital H inside a circle more or less right in the middle of the bypass. I have # H20 in like new condition. Value - depends on if yours is right or not. With the damaged intake & extra mounting hole - if it has the right cylinder then it's $500+ - if not then it's little more than very rare parts so less than half that. Well worth you looking properly then!
herbata
Postby spacebug.049 » Fri Jul 31, 2009 7:17 pm
It does not have the two holes but I do know that Brown had Hurleman make some engines, the Aristocrats. Maybe they used a brown cylinder when they were short on Hurleman's?
spacebug.049
Vintage Brown Jr Motor
Postby Dusty » Wed Aug 05, 2009 6:58 am
spacebug.049 wrote:It does not have the two holes but I do know that Brown had Hurleman make some engines, the Aristocrats. Maybe they used a brown cylinder when they were short on Hurleman's?
Hi y'all,
I read your post and would like to have some info on a Brown Jr Motor I got from my dad. He bought the motor from an Irish tinker, Paddy Thompson in the late '40's. A propellor logo with "BROWN JR MOTOR" stamped inside the logo, together with BROWN MOTORS CORPORATION PHILADELPHIA are stamped on the cylinder sleeve. The engine mount is stamped MADE IN U.S.A. and the serial number C11310. It is fitted with a wood prop which seems to be handmade, maybe in South Africa. The engine seems unused, as the metal on the cylinderhead is not discoulered from heat like the one in the pic. Can anyone share some info on this engine please? It looks a lot like the one in your pic, "Champion" sparkplug and all.
Regards,
Dusty
Brown Jr Motor
Postby Dusty » Wed Aug 05, 2009 7:07 am
How do I get a photo onto this site? :o
Dusty
Postby chiefss » Wed Aug 05, 2009 7:38 am
It's a Brown "C" model made in 1937
Postby Dusty » Wed Aug 05, 2009 8:04 am
chiefss wrote:It's a Brown "C" model made in 1937
Thank you buddy. :D Which planes were these engines used on? What is the size?
Dusty
Dusty's Brown Jr Motor
Postby Dusty » Wed Aug 05, 2009 12:12 pm
Dusty
Postby Dusty » Wed Aug 05, 2009 12:18 pm
Dusty
Dusty's Brownie
Postby Dusty » Wed Aug 05, 2009 12:26 pm
Dusty
Dusty's Brownie MADE IN U.S.A. Hooha!
Postby Dusty » Wed Aug 05, 2009 12:38 pm
Dusty
Brown Jr Motor
Postby Dusty » Wed Aug 05, 2009 12:48 pm
There, got the pics on! Please comment :wink:
Dusty
Postby propwobble » Wed Aug 05, 2009 6:44 pm
1937 Brown C model .601 cubic inch displacement, I believe the basic specs are the same as for the Brown B engine. Please correct me if in error. .875x1.000 bore/stroke, compression ration 6.5:1, approx 1/5 hp at 5200rpm. Hurleman type spark control as opposed to later brown design. recommended prop size of 14 inch diameter by 8 inch pitch.
AMA contests rules cite this engine for models with at least 688 square inches and a minimum weight of 48.1 ounces. Freeflight contest class "c " engine ( this has nothing to do with the c model designation)
propwobble
Brown Jr Motor C model
Postby Dusty » Thu Aug 06, 2009 12:55 am
propwobble wrote:1937 Brown C model .601 cubic inch displacement, I believe the basic specs are the same as for the Brown B engine. Please correct me if in error. .875x1.000 bore/stroke, compression ration 6.5:1, approx 1/5 hp at 5200rpm. Hurleman type spark control as opposed to later brown design. recommended prop size of 14 inch diameter by 8 inch pitch.
Many thanks PW! I had this little motor for many years and eversince remained interested in getting it running. Maybe on a permanent mount or installed in an era model (not to fly though :) ). The engine unit is complete and seems mostly unused. I'll only have to obtain a fuel tank and coil for the Brown C, to power it up. I'd prefer original components if obtainable. My son worked in the USA during 2008. DAMN if only I joined this site then!! He could/might have acquired the necessary parts while there. Quite diffy to reside in Africa viewed from a postage or shipping perspective.
In retrospect of some articles people wrote on this site, I deem that the Brown C guzzles standard petrol/gasoline/fuel :wink: . Not unleaded though. It needs lubricant. Maybe a little more than standard fuel provides :roll: . Does anyone know perhaps what the original designated mixture was, if any?
Nevertheless, thank you all for the info.
Regards - Dusty
"Whether you believe you can do something or not, you are right."
"Piper Pawnee's are not equipped with quit buttons!!"
Dusty
Postby propwobble » Thu Aug 06, 2009 10:27 am
Dusty,
The Brown takes the same fuel as other engines of the era and type.
Look in the spark ignition engines forum under "Fuel for spark motors"; there is a lot of info and good comments about ignition engine fuels.
propwobble
Brown jr (Fuel)
Postby Dusty » Fri Aug 07, 2009 12:31 am
PW,
Great, thank you!
I've already read all the articles you referred to. I'll experiment with the recommended formulas. Well, I first have to acquire a fuel tank and coil. Fookit! Can't wait.
Regards
"If you don't pay your exorcist, will you get reposessed?"
Dusty
Users browsing this forum: No registered users and 46 guests
