Dooling 61 model change
Postby dynasoar » Fri Jul 11, 2008 3:04 pm
Hi Gentlemen,
This is my first posting to the forum. Here's a question to start things off. A Vintage Control Line Speed class is being discussed, with the cutoff date for ignition engines and airplanes set for the end of 1947.
I would like to run my 7-fin Dooling 61, which I believe was introduced late in calander '47. I don't have access to an engine encyclopedia at this time, so could someone check the serial number and date for Dooling's transition from the early 1947 10-fin crankase to the later 7-fin configuration? I believe the transition S/N was about 1500 and the announcement of the new engine was, coincidently, about the same time as the Arden glow plug hit the market.
Will Stewart
dynasoar
Users browsing this forum: No registered users and 3 guests
