Bantam Engine Piston Question
Postby srcmodels » Wed Jan 12, 2005 9:28 am
I have a question maybe someone can help me with I started to clean and check a Bantam .199 and forgot to look when I took apart the way the piston came out (does the angle side on dome go towards the fuel transfer ports or the exhaust side . Thanks Ron
srcmodels
Postby walt » Wed Jan 12, 2005 4:40 pm
Normally, the high side of the baffle goes on the intake side, but I'm not looking at a Bantam piston and I forget exactly what it looks like. On an O&R, the slanted side goes toward the exhaust. Someone here will correct me soon if I'm wrong.
Walt
walt
Baffling baffle
Postby max hansen » Thu Jan 13, 2005 8:01 pm
The baffle on the piston of a loop scavenged engine always goes to the intake side . It is there to direct the fresh mixture up toward the head & not straight across & out the exhaust ,and also to help push the spent gasses out the exhaust . Also watch the port slots on the cylinder as they can be reversed easily on a Bantam ,the highest slot is the exhaust one . MAX H. :lol:
Users browsing this forum: Google [Bot] and 39 guests
