by jerry1927 » Thu Apr 29, 2004 1:05 pm
Some K-K engines have no keys to index the timer cam precisely so that the spark is triggered properly. My prewar K-K has a tapered prop shaft and drive washer/timer cam with a 9/32 in shaft but no way to lock the two in proper position. My postwar K-K has a 1/16 in. key and keyway in the 1/4 in. shaft and drive washer to assure their positions are correct.
Does anyone know the score on this situation? Also, does anyone have stationary points and insulators for these engines?
Dyna-Jet Jockey (Jerry 1927)
jerry1927
by max hansen » Thu Apr 29, 2004 6:20 pm
Jerry do you have both engines yet? You could use one to time the other . Did you see at the bottom of this index where a guy had a bunch of parts for these ,you might be able to chase them down . I reinstalled the ignition parts on one of these years ago for a collector that was emotionally attached to his engine & I was sweating blood when I finally got the cylinder un-screwed from the crank case. Came with a" pop " & I was almost afraid to look but all came out well . Hope you come out OK. MAX H.
Users browsing this forum: No registered users and 94 guests
