Conquest .15 break-in reality check
Ask questions about the RJL K.61, Kraft .61 and RJL/Cox/K&B Conguest .15 here
Postby Cz10 » Fri Mar 09, 2012 9:37 am
Things a bit slow here, but maybe someone is still watching that will know this.
I acquired a Cox Conquest .15 CL that I need to break-in for a nostalgia build of a Jr. Satan.
The instructions I have here
http://www.servimg.com/image_preview.ph ... u=17146591
state in the second paragraph under "Starting and Break-in" that for the second part of the proceedure I should use the propeller intended for flying (their suggestion is 7 x 5) trimmed to 7/8 of the original diameter. That would be 6 1/8 x 5. Am I reading this right? Are they assuming this is on a test stand? Seems like a very small diameter, but I guess the idea it to let the engine rev close to what it should turn with a 7 x 5 in the air?
Cz10
Postby MECOA » Mon Mar 19, 2012 7:49 pm
Here is the owners guide
http://www.mecoa.com/rjl/c15/og.pdf
There is a prop chart there
Return to RJL Engines Tech Support
Users browsing this forum: Majestic-12 [Bot] and 10 guests
