RE KRAFT .61 LINER REMOVAL.
(FOUND INFO ELSEWHERE ON THIS SITE.) INTO THE OVEN AT 180 DEG. CELSIUS FOR 10 TO 15 MINS,(AFTER REMOVING ALL BITS WHICH MIGHT MELT) A BIT OF TWISTING AND OUT IT CAME. WILL REPLACE THE BEARINGS AS THE HEAT MAY AFFECT THE SEAL ON THE FRONT BEARING. BEARINGS ARE OLD AND NEED REPLACING ANYHOW.
CHEERS
